Drilled the counterweights? That is how they did mine as for making it weaker I don't think so, it is not effecting the center line of the crank.
Ok got a few questions that I'm
Not sure of. First off how well will these keys work? I told the machine shop to key the whole crank and this is how they did it. Will it break?![]()
And second. Shouldn't the white for on the crank gear be centered between the two yellow dots on the cam gear???![]()
The other side he only keyed for the balancer then it stops. Doesn't go back to the gear
Well machine shop finished up this morning and picked up the short block. Will start putting it together tomorrow. Also they didn't grind it to balance it, they drilled it,anyone know how well that will work? I've heard drilling makes it weaker? True or false?![]()
