Stuck in regen low #5 EGT
77cruiser
114
Frost Bite Falls
Started a regen towing today it took 15 miles to get up to 900 deg. & only got up to 940.
Needless to say regen never finished in 45 miles.
2 codes from my Idash PO422 & P24A0
Woody35
87
42
FWIW I had a bad EGT Sensor on my LML off the DOC. Regen would start and would get to somewhere in the ballpark of 900-1000 degrees. Then it would shoot up to 1600 degrees and Regen would stop. Temps would start to cool off and the sensor would read normal again. Regen would start again and the temps would shoot up again. Regen time progressively got longer and longer until it finally set a code. During normal driving the sensor was accurate.
8,172
Yup, lots of diag to figure that out. Not uncommon for the 9th injector to die. Egt sensors seems to last longer but those fuckers always sieze coming out
8,172
Trying to decide on the tune their tow tune is 60hp. 5th wheeler is 14K loaded.
What year is it? Whos tunes? Becareful on those.
60hp on a 17-19 is fine, just add the epc blocker in the trans. 60hp on the 10 speed, better get a tcm tune or ratiotek kit
