I am getting this "Service Brake System" in the DIC. When it happens the bell like low fuel bell goes off for about 15 rings and the ABS, Brake and Engine lights all come on. The trans goes into some sort of a limp mode where what ever gear its in when the code throws, that is what gear it stays in. If its first I can't get anywhere and reverse doesn't work at all when this happens. I have to pull over turn it off and sit for a few minutes for it to reset.
I had at a dealer all last week and they couldn't get it to do it so they couldn't find out the problem. On my way home from the dealer I pushed the brake pedal it vibrates similar to when you brake hard and the ABS is working but wasn't braking that hard at all. Then after the vibration the bells go off the lights light up and the trans is in limp mode again.
Anybody have this problem or know what it is? I am afraid to drive it anywhere for fear the brakes may not work all of a sudden.
