Needing some help diagnosing a rough idle. Truck starts and then the balance rates will get progressively worse and then level off around -4. However cylinder 2 and 8 continue to climb to -12 and -10.
After seeing this my first thought was injectors, so I switched them with other cylinders and the rates remained the same in cylinder 2 and 8.
I then did a compression test in cylinder 2, 6 and 8 which resulted with 350 psi +/- 5psi.
Then, I used DVT in EFI Live to individually turn off each injector and see if I could notice a change in idle. When I turned 3 and 7 off (individually), there was no noticeable change. However if I unplug the injector itself on both of those cylinders, the idle gets more rough.
Any input is greatly appreciated.
Truck is an LBZ with a tune and exhaust.
