LBZ: Rough Idle, No Related Codes
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
Needing some help diagnosing a rough idle. Truck starts and then the balance rates will get progressively worse and then level off around -4. However cylinder 2 and 8 continue to climb to -12 and -10.
After seeing this my first thought was injectors, so I switched them with other cylinders and the rates remained the same in cylinder 2 and 8.
I then did a compression test in cylinder 2, 6 and 8 which resulted with 350 psi +/- 5psi.
Then, I used DVT in EFI Live to individually turn off each injector and see if I could notice a change in idle. When I turned 3 and 7 off (individually), there was no noticeable change. However if I unplug the injector itself on both of those cylinders, the idle gets more rough.
Any input is greatly appreciated.
Truck is an LBZ with a tune and exhaust.
stibuilder
Oct 17, 2016
239
Snoqualmie, WA
Have my truck in the shop for a similar issue right now. It idles file but #8 is out of line +6 upwards of 10. Once you drive it you notice a miss. I also moved injector 8&3 as they both were new and it stayed in #8 i then replaced the whole engine harness with the same affect. I have even gone as far as the ECU and still nothing. Good Luck! my truck is also a LBZ/LLY its in a Kodiak.
gmduramax
Shits broke
Jun 12, 2008
4,185
326
Nor cal
Is it giving you the rates for the correct injectors? On a LBZ that had a bad injector I couldn't turn it off with the DVT but if I unplugged it the knock went away. Why wouldn't you check the comp in all the cylinders?
