Replaced injectors, still a haze
Duramaxduner
Oct 28, 2013
168
I just find it hard to imagine that they would all be bad right away like that. I thought they would at least last a little while and they are just as bad as my old ones, I mean they did come with a one year warranty? Right from the start there was almost no change at all? How can companies sell these "reman" injectors if they are all bad?
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I would still do a compression test to see if one cylinder is low on compression. If one is really low on compression the fuel in that cylinder will not get completely burned and make a white/light gray smoke.
Duramaxduner
Oct 28, 2013
168
^^I think I will start there. Is that very common? Keep in mind there is no check engine light and the truck runs great.
Awenta
4,090
CT
Check injector return rates too. You can also try turning them off one at a time
Duramaxduner
Oct 28, 2013
168
So I checked my balance rates last night, at operating temp, 170 degrees, these are my results.
1. 0.91mm
2. 2.22mm
3. -2.25mm
4. -0.55mm
5. -1.18mm
6. -0.54mm
7. -3.55mm
8. -1.80mm
