Rear Brake Rotor Removal Question
Krazykid
<-Daily Thought Process
Nov 22, 2008
247
Upstate, SC
How? I got the brake caliper off but the rotor won't budge? Front rotors came right off with no issue. Is there something that I have to do to the e-brake? Thanks for the help.....
13,597
629
They should slide off. You either have some corrosion holding the rotor to the hub or you have a lip inside the parking brake drum that is catching the parking brake shoes. If it doesn't move at all, my guess is you need to tap it with a dead-blow to break it free. If it was the parking brake, it should wiggle a little.
Krazykid
Nov 22, 2008
247
Upstate, SC
Thanks guys......I know I don't have a "BMFDBH" but the small one that I do have I beat the Sh*t out of the drum and no go? Of course I only tried one side.
Rhall
Old Skooler
Aug 12, 2006
2,241
40
Texas Y'all
You dont have the parking break on do you? Ive had to beat mine pretty good, i usually end up replacing them cause i beat the shit out of them.
Vrabel
TOYAHOLIC
May 22, 2008
3,434
56
Hewitt, NJ
spray hub with pb blaster. dont make direct contact with head of hammer and rotor, use a block of wood.
tinman22
715
Stillwater NJ
if hes using a dead blow hammer he can hit directly. if using Ball peen or claw or something a block of wood would be recommended. or one of those brass head hammers. definitely need a penetrating oil IMO
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
Does this apply to the dually axle ? Guy in the shop at work pulled my axle shafts and all to change out my rotors a while back. I looked at him like he was crazy but he was real convinced he was right.
Vrabel
TOYAHOLIC
May 22, 2008
3,434
56
Hewitt, NJ
I haven't had a newre dually apart yet. But if its a "Hubless" rotor, they just slide off. Also when you replace, a little anti-sieze is a good idea. ;)
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
You could check the brake rotors for two extra holes around the hub. Mine have them and I just put a couple bolts in and tighten them. Pulls the rotor right off.
