Pulling with lowered truck
Dante2795
64
Looking to do my first sled pull but I’m worried my truck being to low will cause problems. It has 3in shackles with 2 leafs removed and I don’t have air bags. Will that cause too many issues with raising my front end? Any info would be greatly appreciated.
5,059
its certainly not going to help you in pulling the sled unless you have a hitch that will raise way up. you want the sled to pull the ass end down and drive it into the ground to help get more traction. By no means does this mean you cant go out and have fun.
as for how it sits, unless you have axle wrap bars, i wouldnt attempt it. pulling leaves will make that thing want to axle wrap like crazy when under load and power. if you still have the stock overload, you can clamp that to the leaves that are left to work as a axle wrap control (old school way alot of guys did way back when)
Dante2795
64
Truck does have traction bars so I’m not worried about axle wrap. Just not sure if it being so low will even be worth it to hook it to a sled
13,599
633
Get some pulling bump stops and you should be good to go.
Dozerboy
4,826
402
TX of course
So what if your lowered your still going to have fun right? You might even get lucky and do pretty well.
