I'm thinking of turning it completely off but wondering if it will idle loud.
Turning it completely off will require some drastic changes to the main timing tables in order for it to run. A diesel without pilot will run between 4-12 degrees of timing at idle depending on what pump it's running. A diesel with pilot will run anywhere from 4 after top dead to 0 at idle due to the pilot injection combusting before the main injection. Basically if turned it off, you would sound like a 7.3L powerstroke by the time you got enough timing to it to keep it running and to not pour white smoke out at idle.
I'm going to shut it off at 2000 and see if it helps the loud rattle sound
