My 04 LB7 has a problem that is really angering me and the wife. The passenger side battery is slowly leaking acid out the vent. The AC delco factory batteries done this last year, I replaced them both with new exide batteries. The new passenger side exide done the same, I replaced it and now the new new one is done is the same thing again. This is wrecking havoc on the paint around the battery and leaving a huge orage rust stain on my nice new asphalt driveway. the alternator checks fine, all connections have been cleaned and sprayed with protectant. Voltmeter never reads anything out of the ordinary, the truck always starts fine. I'm not the only one having this problem, I've read were several people have had the same issue. Please help.
And now for my rant: I posted this on this site for a technical solution not a way around the root problem, which is all I could come up with over the the DP. So need not post if your solution is to replace the batteries with Optimas, (which I know can be mounted upside down), I DO NOT CARE. And no, the acid is not coming from the damn postive terminal, the stud is NOT to long, it's coming from the vent. Thank you, sorry for the rant.
