LB7: Parking brake cable misery
Jules1525
Jun 15, 2016
29
My 02 lb7 was *supposed* to go in for safety today and finally get plated. One little thing left I needed to finish- connect the new e brake cables. After a few hours I got one on but I can't get the two of them on.. what am I missing? There must be a trick I don't know for this right?
Everything happens for a reason though. The blower motor decided on is the way to be while I was fighting with the lines so either way this wasn't the day I was winning.
Jules1525
Jun 15, 2016
29
Hats? This is sounding like something I can't finish with it on the ground. I've never done e brakes before. Only pads and rotors, apparently I never want to do this again! Haha
1,736
1,736
Just jack up the side you cant get on, remove the rotor and put the cable on.
Jules1525
Jun 15, 2016
29
Thank you for the help! Got it hooked up and she's now (finally) plated.
Now to get used to the gauge readings. Going from gas to diesel I keep checking to make sure things are where they should be.
