P0841 and P1711 after wiring harness swap
mojito5000
52
5
Oregon
I had some codes that pointed at a wiring harness issue, I got a new one and the pressure sensing board, both Rostra branded parts. For the most part everything went smooth, and I thought I got everything swapped out (couldn't use the plastic loom on the new harness, so I used the original, all the wires lined up and were the same length).
I got the transmission fluid to the marks, but I have the two codes above now. The transmission is in limp mode after a few seconds of being run. I can clear the codes (Tech2), but they come back almost instantly.
Did I mess something up when swapping the harness and the pressure board?
On a good note, my trans temp gauge in the dash seems to be displaying the temp correctly for the first time since I've owned the truck...
Ron Nielson
930
234
Berryton, KS
  • P1711.pdf
