I had some codes that pointed at a wiring harness issue, I got a new one and the pressure sensing board, both Rostra branded parts. For the most part everything went smooth, and I thought I got everything swapped out (couldn't use the plastic loom on the new harness, so I used the original, all the wires lined up and were the same length).
I got the transmission fluid to the marks, but I have the two codes above now. The transmission is in limp mode after a few seconds of being run. I can clear the codes (Tech2), but they come back almost instantly.
Did I mess something up when swapping the harness and the pressure board?
On a good note, my trans temp gauge in the dash seems to be displaying the temp correctly for the first time since I've owned the truck...
