My 02 2500 does not read the temp on the mirror. It is completely blank. The little green light is on at bottom of the mirror. Any common things to look for? I have seen bad temp sensors before but they still read something.
Looks like standard flux. Usually you don't need to remove it as it's not conductive when cold and dry. You might have a cracked solder joint and you moved it into a position that makes connection. If the problem returns, reflow those solder jointsWell I think I fixed the temp read out. Finally took a look at it. Had 12 volts at the connector. Pulled mirror apart and found this. Lightly brushed the corrosion off and it is working now.
