That is actually the fifth time I have gone up that canyon in the last 800 miles and I have towed the boat up a different canyon with a long 6% grade but it was 4:30 in the morning and the outside temps at the summit were only 48 so I did not post results because I want the testing criteria to be as close as possible. But it is supposed to be in the triple digit temps all week so I will run the canyon every day seeing that it is only five min away from work and we will see what happens.That run up the canyon was the best thing to do. Next time you do that there will be a difference.
It takes heat, and pressure to fully plate the moly to all the metal sufaces inside the engine.
