Just finished Coilovers for front end, Dual CP3 in the next few weeks and some other random stuff.
I'm making all my cold side pipes out of aluminum instead of steel. Making new front a-arms, so I can get my alignment better. And oh yeah installing a parachute just in case I hit that 150mph.
Can't wait for race season!!
And hopefully a trany input shaft that can handle your awesome VGT power!
I would like to switch to coilovers on the front end and lower it alittle more but it will require c-notching the frame and I'm not looking forward to that! Will be twinning it most likely also...![]()
I'm making all my cold side pipes out of aluminum !
is that so yo u can run vanjen clamps?
Rods, 60overs, LBZ regulator, etc. Hoping to break into the high 11s this summer!
No. My old piping was about 2-2.5" sort of say the intercooler or turbo and I was having problems with the boots ripping from so much boost. My aluminum pipes will only have about a 1/2" gap between pipe and intercooler and turbos. I'm going to try it this way and see if the boots will stay together. If they don't I will have to get the DDP or PPE boots.
I'm also installing a 6" air shut off from Engineered Diesel. That will also be made out of aluminum 6" piping.
I know, goal is to get my charger made into a 72 and go dual fuelers over next winter. Then run 11.50s and still be reliable for a lot of street mileage. I just got nervous pushing it as my DD.You don't need to build the engine to go 11's![]()
Broke the 4r100 input shaft?
