Odd question
Keith T
May 29, 2017
I'm new to this forum. I have a odd issue. I have an 2004.5 when I'm coming down a good grade or coming down a mountain road and then when I get back into it I have no power and I get some rattles in the motor. Some times it won't shift down. Sometimes it goes away when it does shift other time I stop and then when I start again it's fine. I have no idea. Any help or ideas would be a great help.
3,058
Welcome
Sounds like it may be going into limp mode or something like that. Do you have a code reader that you could check the codes when it happens again?
Keith T
May 29, 2017
I have edge on it. It has 130k. It was going in limp mode when I get on it to pass someone. I ran it in limp mode for about 2 miles and it threw a code. It was reading glow plug mod. I changed it out and it hasn't went into limp mode like before but now I have this problem
Keith T
May 29, 2017
Thank you all. I have taken my edge out and I will see if that is the fix. How or why does the edge make it do this? I very rarely run it in level 4 or 5. Most all the time in 2 or 3. Thanks again.
3,418
Edge had an issue with the circuitry in their modules. Components would fail and cause the engine to cut out like you describe.
Also, moved this into Tuning/Logging.
