So in my quest to tighten quench up and do so with HG's, a few friends have raised a concern with my thoughts on running A's.
Right now, my tallest piston is .011 measured at the wrist pin and hits .013 measured at top of the piston with the piston rocked "out". The rest measure .010-.0105. I ran C's before and intake valves average a -.027 depth with the shallowest at -.024 at the outer ridge away from the piston (other end that's over the piston measures .026). Exhaust averaged -.035ish. That was all measured with a deck bridge dial indicator on the valve faces and the old head surface cleaned. My quench was .028 at the tightest based off wrist pin measurement.
I'm looking to go to A's but I do t want the valves to hit the Pistons which were mine and Steves concerns. Based off my thinking, the new heads have the intake valves recessed to an average of -.028 and none over -.0275. Exhaust averaged -.038. So the valves are really close to where the old heads were, if not a bit farther up. So if I ran A's, my quench would be .024 basing off the wrist pin measurement which is still below jons suggestion of no less than .020. Should I worry about piston to valve issues or am I/we over thinking this?
The tallest piston is also .002 taller than GM recommends for an A gasket which again makes me wonder.
