New fass losing prime.
motoking_1990
1,950
Terre Haute, IN
I put a new fass on yesterday and now i am having a priming isssue. Only takes about 5-10 pumps on the ball and its hard. Doesn't take long for the prime to go away either about 5 min or less.
The previous owner put oversize lines on when he put the raptor pump on. The raptor was mounted to the frame rail, this pump sits on the left side of the fuel tank. I had to run the lines different but I dont that matters. Anyone know if the pumps are preset or should I try turning the fass up to keep prime? Any ideas could be helpful.
andy-stevenson
Jul 7, 2013
838
Anyway you bent the feed line elbow on the fuel sending unit?
When I installed my airdog I bent the rusty elbow and put a split in the side of it. So it was sucking air in, truck would idle fine, but kept dying when I tried driving it.
motoking_1990
1,950
Terre Haute, IN
no its rubber from the elbow to the pump. all i did to the elbow was plug the line into it. just checked to make sure its not kinked or bent.
Awenta
4,090
You can modify the stock pickup but it should run on a stock pickup with no problem.
Your primer pump maybe be leaking. No leaks on any lines?
1,601
You have a pinhole air leak somewhere in the system. It will not be easy to find. Go back over everything, including the fuel filter. Good luck.
02greysixer
1,829
7
North Central FL
How far have you driven it since installing the Fass? Did you prefill the filters before starting the pump? If using the factory pickup I've had a hard time getting air bled from them upon initial assembly. Took a few test drives before the pump quieted down and truck started normal. Are the filters in the correct places? If memory serves the water separator goes toward the rear of the truck (assuming you mounted it how/where fass says) Are they the proper filters?
Sent from my SAMSUNG-SM-G870A using Tapatalk
motoking_1990
1,950
Terre Haute, IN
The filters were on it already in the box. All I did was take them off one at a time and put oil on the o rings. I installed a whole kit with filter and everything. I did not pre fill the filters. I sprayed wd in the engine side like instructions said. I also mounted the pump per instructions. Only thing I didnt do was tie in above the fuel cooler like the instructions said because previous owner deleted factory fuel line.
motoking_1990
1,950
Terre Haute, IN
I am getting diesel on top of the main plate. Not sure the exact name of the part. Its the flat center section of the pump everything attaches to it. A main body of the pump i guess you could call it. Something is leaking on top. I will have to figure it out later in the week.
02greysixer
1,829
7
North Central FL
I did have to disassemble a brand new one once that had a leak right out of the box. An O-Ring in the body was pinched. Replaced it and good as new
