I just finished some R&R on my truck. The fuel level sending unit in the tank wasn't working. So I thought this would be a good time to install the Airdog I've had sitting in the garage for a while now. I dropped the tank, changed the sending unit and installed a PPE billet pick-up. Then I installed the Airdog added about 8 gallons of fuel and attemped to prime the system. After filling the filters with fuel several times and endless bleeding at both the output side of the Airdog pump and the factory bleed screw. I am at a loss for what else to do next. I have gone back and double checked that the plumbing is correct, there are no kinks in any of the hoses and there are no air leaks on the fittings. The pump is pulling a vacuum at both the inlet side and at the fitting on top of the tank. I just can't get it to pull any fuel out of the tank. Anybody out there have any ideas?????
