Question: Mileage while towing
Kartmnn
Oct 27, 2011
244
East Providence RI
Head wind and how much wind the load pushes affects it the most. Period! As a boat hauler going east to west north to south and all other ways take my word. Hills you can adjust your foot but wind you are going to burn it no matter what...
GMC_2002_Dmax
The Still Master
I have a 05 Lly 4500 4x4, with the 5.13 rear end, single cab, with a 12' flatbed. single Efilive tune, 5" exhaust with muffler. K&N intake, egr del. , 245/19.5 tires. cruising around unloaded on hwy it gets 15-16 mpg.12-13 in town.
Towing our toy hauler which is at 10k, it got 8-10 on hwy
...granted it is gearbound on the highway, but if you try and keep it close to 2000rpm or under, or under about 55mph is where it runs best.
This guy likes to drive at 75mph......and he likes a little power, he won't drive "55".
:thumb:
1,458
Only two things different between you and me. .75. Vs .70 od and the height of the vehicle
SmithLBZ
Jan 11, 2012
91
TN
Mine will run 75, but with the 245s and the 5.13 gear its turning almost 3k and begins to drink fuel badly. I wish I could convert it to a 6-speed to help out on the highway. The PPE conversion kit will not work, as Dan has told me you need a tow haul signal to lock out 6th gear . Sorry to go off topic Tony.
1,458
Im 2500@70 you have little shorter legs then i do but not by much im running4.63 and 225 19.5
SmithLBZ
Jan 11, 2012
91
TN
How I use mine for pulling trees, hauling heavy loads such as a bobcat short distances, the low gearing is awesome. If I were going to be doing lots of hwy towing, I would definitely change the rear end gearing. Also would be nice to get some bigger tires that would help some on the hwy, but I don't have 1600$ I want to spend on 6 new tires.
1,458
gear swap is cheaper...
