Manual control engine fan
Redneckgt
Jul 15, 2018
Is there a way to manually control the engine fan on a lbz? I pull my camper that's around 9k. Doesn't seem like the engine fan likes to kick in until temp hits 230.
clrussell
pro-procrastinator
Sep 23, 2013
6,034
527
Your truck should not get hot towing now 9k. You have something causing an issue (cooling stack air flow, fan clutch, etc)
How hot of a tune are you on, where when it does it (mountain pass or flat ground)?
Bulldogr6
Feb 18, 2012
25
Wester Mass
230° is not anything to worry about. If the fan does not keep it around that temp then worry.
Sent from my E6782 using Tapatalk
Redneckgt
Jul 15, 2018
It's a edge tow tune. Its mainly during the hills.
Truck is pretty stock other than the edge. Even still that the fart breather on it.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
45
ZEPHYRHILLS, FL
230 is not hot, and is where your stock fan starts locking in at speed. Make sure your cooling stack is clean and replace your fan clutch(most manufacturers reccomend replacing them after 5 years or 75K miles as they are a wear item).
