Anybody tried MAF timing yet versus MAP? I was just thinking about it I bet it would be killer for spoolin fast as some very lazy timing numbers to be put in the low boost areas, then the grams per cylinder (higher boost) is up your off to a better table. 3 to choose from based on boost low, med, high sounds like it would be decent instead of stuck on one baro table most of the time. I was just wondering if anybdy has tried it yet and if it was worth while.
