Yesterday I noticed my low coolant light came on. So I filled it up with about 2 glasses water. That same day it came on again, but I could not find where it was leaking, there was none leaking on the ground and I couldnt smell any.
I was worrying it might be head gaskets becuase I can crawl under the truck on the passenger side and see in between the block and head has a oil stain, but it dosent smell like coolant.
So I went out there today after driving and noticed it is dripping pretty good. So I put a bucket under it and it leaked out about 1/8-1/2inch and now after about 2 or 3 hours its slowed down to no leak. I will try to get a picture but it looks like its coming from somewhere around where the radiator hose comes out of the engine. Also I can see where it has made a trail on this black tube below the drivers side exhuast manifold. (Is this part of the egr?)
So im thinking it might be the water pump? But I can't find the weep hole to see if that is where it is coming from. But I am still worried I might have a head gasket problem after seeing the oil stain in between the block and the heads?
The truck has 135k, 350-500rw tune running about 26-30psi with 2000us-3000us and 22-27 degrees timing since I bought it at 120k. I don't no the life the truck had before that but it was a completly stock LLY, so it may have been overheated?
btw, the radiator hose is not pressurized in the moring but it is collaped when cold so I put a new cap on it.
