Looking for help in right direction.
Michaelmcp96
Mar 18, 2024
3
70560
Looking for help with 2013 Chevy 3500 lml. Currently at a no start fuel issue. Purchased truck needing injectors which I have previous balance rates. Truck ran perfectly fine despite this. With Wanting to hold off until I was able to also do a cp3 conversion I just decided to rebuild and do new seals and orings and replace fuel return line. After replacing it would not start but had 5000psi at fuel rail while cranking. Only code that appeared was a p2296 which later went away. Kicked on for a second then redied where I found diesel in my oil and exhaust so I inspected cp4 which was fine no shavings or codes. But all 4 passenger injectors which were going out of balance rates (-.) now flooded cylinders at one time. Glow plugs are covered in diesel and fuel heavily dripped as I opened fuel lines and removed return lines. What would have caused all 4 to suddenly flow so much diesel at one time? Was told the return line would build its own pressure after replacing but saw someone else have to add air into part of line that goes into T’ portion of fuel return line by driver rear engine. What may cause and what should I test or do. Thank you!
Michaelmcp96
Mar 18, 2024
3
70560
Sounds like the injectors are leaking fuel pretty bad through the nozzle? You rebuilt 4 injectors or the pump?
I replaced fuel return line and all injector copper seals and body orings and a couple orings for return fitting. Nothing else. All passenger injectors were actually in a negative balance rate before. Now they all flooded cylinder leaving diesel on glow plugs and standing diesel in injector cup. Only code I got was a p2296 that went away after.
1,732
Maybe turn the injectors upside down and see if they leak while cranking over. Should be very distinct spray mist. A leaking injector may not shut off and continue to spray
