Just rebuilt my trans and it has approx 100 mi on it. Sometimes it'll lock up in 4th gear around 35 mph on light throttle. Will unlock when shifting to 5th then lock again when it's supposed to around 45 mph. Trans build consisted of altos for c1, raybestos for c2-c4 and I reused the c5 (they looked perfect when I tore it apart). I put a 6 speed drum in it also. Used the trans go converter valve with longer spring and no ball (same thing I did to my last trans I built and never had a problem) also replaced speed sensors, pressure manifold switch and internal harness. Trans shifts amazing and smoother than my first trans I built. I just get an occasional early lock up in 4th gear with no codes. It's also an 03 trans in an 05. Only code is for G solenoid. I'll be sending the TCM out shortly to have mark reflash it with an 01 software.
