Do you know if you can flash an LLM calibration into an LBZ- E35 on a bench just to read it out?I have it in EFILive format but not HPTuners. HPTuners is nowhere near as common on the duramax side. If I had an LMM ECM I could flash it with EFI then read it with HPTuners but the only one I have here is DOA.
That's a good question, I honestly haven't tried. I do not know to what extent the controllers differ beyond E35A vs E35B.Do you know if you can flash an LLM calibration into an LBZ- E35 on a bench just to read it out?
I'm pretty sure the answer is noDo you know if you can flash an LLM calibration into an LBZ- E35 on a bench just to read it out?
I wait...Hang tight ill try and get to my tune laptop tonight
The last post was 8/17/2023 so it's been quite some time.is this still a active thread?
HPTuners repository as stated above. You could also read one out of an LMM.know where i could find a stock lmm hptuners file.
