Needs some ideas what can cause coolant in oil. Already eliminated water pump, oil cooler and turbo. No combustion/compression going into cooling system. Have the bottom oil pan removed and it's seeping in around cylinder 4, pressurizing cooling system to 10-15 psi. Would a head gasket leak but only coolant into oil?? No injector cups on a LMM. What else to check before I tear it down.
Engine is built, has arp head studs. I think it has around 60k on the engine, maybe 80k .
