LML Tcm
ikeG
Oughta Know Better
Apr 19, 2011
2,462
146
Western PA
www.facebook.com
Does heat soak bring on the dreaded bad tcm issues? I have one here that will drive fine until you stop and let it idle. Trips a dozen dtcs. Voltsge, over temp, etc
Sent from my SM-G960U1 using Tapatalk
2,130
I've never heard of it on a Duramax. But plenty of times for other electronics. Usually caused by a cracked solder joint. Only way to fix it short of replacement, is to reflow the solder. Happens most often at the chips or the connectors.
The 1st generation X boxes had this issue. Fixed one for my cousin by fluxing the chips and putting it in the oven to melt the solder.
Dallas S
486
33
Alberta
I have a “test” T14 here that fails every time internal temp hits 76? 67? Degrees. There is a PID for TCM temp. Our “test” unit always works cold, and when it hits that certain internal temp it appears to go into a relearn mode(increased rpm, random clutch application)
5,800
IIRC the overheat is something to do with lack of heat transfer from the chip to the heatsink, could be a cold joint too. Evan had a truck come in while i was at his shop that did the same shit. Kory said "put it in the freezer for a bit, probably works fine after you put it back in". sure as shit, it did.
ikeG
Oughta Know Better
Apr 19, 2011
2,462
146
Western PA
www.facebook.com
The one I have here now fails at 116 degrees everytime. So in this cold weather, it never gets that warm until you stop. Then it slowly heats up.
ikeG
Oughta Know Better
Apr 19, 2011
2,462
146
Western PA
www.facebook.com
ParisWash
Nov 23, 2021
Any update on this issue? I have a new replacement from GM with less than 200 miles on it and I have a feeling it overheated itself just now. It’s cooked a few transmissions and I would love to find an answer.
