x2. They look awesome!
You try using just the silicone clear coating of prop speed yet? I use it without the etching primer on outboards to avoid anti fouling paint, works great and is clear so its hard to even tell its there...
Anybody know how the engine cooling requirements for a duramax compare to a BBC ? I assume the duramax needs more but how much more?
Example, take a lb7 radiator and install it in an 8.1L truck. Watch the 8.1 overheat.
Lbz has 60 more hp also.
You have 2 engines of equal hp, one Diesel one gas. We all know the Diesel is running more effiecsntly (using less fuel) so from a thermodynamics stand point it is required that the more effiecent engine run cooler. It has to. The Diesel cycle is adiabatic, meaning heat is contained. The Otto cycle, not so much.
