You’re in the right spot, it’s just like FERM said, not many people have gone this way and there isn’t much info to be shared since that’s the case. You may be better off getting the electronics from an 03-04 lb7 to use. I would imagine you will have countless hours tracing and making new harnesses to make the truck function properly. The 01-02 use a standard style of harness whereas 03 and up use a canbus system and they aren’t compatible in the least bit. You will essentially have to rewire the entire truck to make an 01-02 harness and brain work in a newer truck, basically turning it into an 01-02 truck. As far as I know, everything will be different, from window switches to the BCM to your lighting circuits. I could be wrong on those, but I do know they communicate differently. It’s the same concept as the differences in 95-99 and 99-02 trucks. Nothing will be plug and play. A stand-alone harness might be an option but I don’t know that for sure. In theory it would work but not sure if you’d lose functionality in other parts of the truck.
