LLY new TCM won't communicate after TCM replacement
LBZ_Baker98
207
Texas
We had a LLY come in the shop with a intermittent issue, went through diag and came to conclusion TCM needed to be replaced. Got replacement from dealer took it to be programmed and they said it wont communicate, they warrantied it out got another same thing. When new TCM is plugged in they cant communicate with ECM or TCM. But with old one plugged in it works great until the intermittent issue pops up and will communicate with everything! Any ideas? TIA
815
Sadly you may have to bench flash the unit as mentioned.
My LLY Truck reads and flashes the TCM through the OBD port just fine. However my friend's LLY has an issue with Noise on the communication bus. I can read it but I can not flash the TCM.
Both trucks are stock with no aftermarket components installed. He did have an issue with his ground to the TCM and he had to run a new wire. But according to the logs something is active on the communication bus.
Reactions: 2004LB7
