I got a new regulator for my personal truck in Thursday night and got my dremel out and used the round shaving bit and carved away the plastic till I could bend the plug over. Then I coated it in rubber insulation spray and then gorilla glue on top. Now it's as hard as the oem lbz reg is except it's a straight plug with no ninety so it fits on an lb7. The picture is just after I finished carving away plastic before I bent the plug over.
For those of you that didn't know how to do it and what the finished product will resemble, there you go. The last one I got was a dud from the factory.
. Finished product
And I finally got a topside creeper cause I'm getting old and my back can't handle bending over the engine bay for an hour yet alone four for an injector or a head job.
2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, Rick Fletes Dsp 5 on v2, 33x12.5 nitto at on 20 inch American Racing 20x10 wheels, Stage 5 Built Transmission by Mike Cole with triple disc billet low stall converter, 4 inch Injen cold air intake, Profab Intake Horn, Batmo Wheel, PPE Race Valve, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust axle dump, lbz cp3 pump, Dual Yellow Top Optimas, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Upper Contol arms, Drilled and Slotted Rotors on all four Corners, FED Y Bridge, Shantz Custom Fab Traction Bars.
