I'm lost here. I put a 2006 LBZ with the Allison 6 speed transmission and all the wiring harnesses and computers in a 94 K2500 (the TCM and PCM are from different vehicles though). I even included the dash and steering wheel even though the airbag was popped. The problems I'm having is when I shift into reverse, neutral, drive it has a very violent shift. I don't have the shift indicator at all and when driving forward it won't go over 1200 rpm. When in reverse it will go a little faster up to 1500 rpm. When in Park it will rev it's full range. When I go to start it the fuel gage seems to work and then it drops to empty and the light comes on. I have the cel on as well as the parking brake and abs. I am using the brake system from the 94 (which I think explains the parking brake and abs) but the gas pedal is from the 2006. I have not hooked up any wires to the brakes yet which I don't know if that could cause any problems yet. I have an AFE intake and I used the EFI live to get past the VATS but I have not loaded a tune yet. I changed the fuel filter as well. The codes I see with EFI Live is:
P0504- Brake switch circuit 1-2 correlation (I'm thinking because the brake electronics aren't hooked up yet)
P2068- fuel level sensor 2 circuit high voltage
U0101- lost communication with TCM (this one I get 5 times)
The last two won't clear either.
Can someone please help me fiqure this hard shifting and not being able to go over 1200 rpm. I done a lot of searching but I just cant figure it out. Is it one of the limp modes or communications or solenoids? Thanks,
