im a new member here, i had this posted on the duramax forum and was told to move it here soooo here it is...
okay so i have a 2003 lb7 ccsb 4x4 and a 2006 lbz motor ecm, tcm, harness, and we (me and Chris Bibby @ C and P equipment) are swapping my engines it started out slow but now we have the harness and motor in the truck but i have heard two different stories and need to know which will work if either (one has too)
option #1
Talked with a guy named Jeff @ Fleece performance as far as what i needed to get the tranny and computers to talk... i have a built 5speed and didnt want to loose it so they recommended a 6speed valve body and the internal neutral safty switch so the tcm would plug directly in... and to wire the harness at the fuse box> i.e. take the pin out scematics for both trucks and make the LBZ harness match the LB7 harness so theoretically everything would work.... question is will it???? i have had a battle getting the data on the pin outs and still havent gotten one that is correct have tried alldata online and a disc from gmc and chevrolet dealers and neither would match the original or the 06 harness so i cant swap the pins
option #2
i was back and forth with the gmc dealership they couldnt believe neither there alldata online or ther gmc information would work but it wouldnt so it talked one of there techs in the back he told me what i was trying to do would never work with out the U-BEC (fusebox and dash harness) he said because my 2003 is a low speed comp system and the lbz uses a high speed but i have both the lbz ecm and tcm and harness sooo whats so different about the 2003 interior vs. the 06 or even the 2007 classic truck.... i dont know which rout to follow?????
any help or insight will be appriciated i know that im in over my head but this can be done im just over my budget and this swap is about to kill me,,, im not going to just give up cuz id have to start over again with a different motor......... plz
hope this is in the right spot.
option #1
option #2
