Yes it would change with a temp sensor problem but not that much
Fuel timing could change if you did something to a temp sensor etc
Then put the allilocker back on and see if it runs good again lol
The bale connectors never got unplugged & plugged back up during the uninstall of the allilocker, did they?
Did you try starting it w/ fresh fuel in a can yet?
monitor injectors? Monitor cam & crank voltage?
unhook dual cp3 & try running it?
Does the dash show correct rpm? I googled the 0374 and found that's a "high resolution" crank/ signal. You would have removed a wire tied to measure rpm for 1 of the 3 thresholds for the allilocker to lock. You probably messed up the engine speed sensor wire. Iirc it's a white wire
Very sorry to see it being way to common anymore, for built motor trucks' having all kinds' of issue's. Shortly after the new owner has taken possession. Honestly make's me question people's integrity. I hope you get it squared away, and are able to enjoy the new ride.:thumb:
The brown wire is just the TCC Wire. Shouldn't cause any of these issues.
Yeah, the allilocker is just a bad coincidence. Try a new ficm?We know this.
The Ali locker and TCC wire is a moot point at this time. The issue at hand now that the truck cranks but won't start. And we've gone over everything in this thread....if you read all Quinnells posts.
