LB7: Lb7 loping/running rough under light throttle
Bustedknuckles
Honey Badger
Sep 25, 2010
1,309
32
Hagerstown MD
I just noticed today that if I'm idling and apply SLIGHT throttle, barely enough too raise the rpms my truck will start shaking and running rough, any more and it goes away and it runs smoothly at idle. It acts almost like it has a mild lope tune. Has anyone else experienced this? Is it normal or is it a bad sign? TIA
Bustedknuckles
Honey Badger
Sep 25, 2010
1,309
32
Hagerstown MD
No, no smoke at all on startup either. I have a airdog too so I'm hoping its not injectors! I just thought about that I forgot to put additive in this tank......
Sent from my Evo while driving.
Bustedknuckles
Honey Badger
Sep 25, 2010
1,309
32
Hagerstown MD
I have a dsp5 with tunes from rob coddens so thats ruled out. I'll check balance rates tomorrow and expect the worst. Thanks for your advice!
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Reflash and see if it persists. Sometimes the ECM can get stuff "stuck in it's throat", and a reflash can clear certain tables that can't be seen. Rare, but it happens.
Evan@InglewoodTrans
yerp
3,118
65
Western MA
Ironic this question came up Ive had the same issue for a while. It doesn't do it unless you just barely set your foot on the gas it's strange.
Evan@InglewoodTrans
yerp
3,118
65
Western MA
I hadnt had the problem for a while and I switched tuning the other day and noticed it again so i think it could be it. Balance rates are good and the truck runs perfect otherwise.
Mike_S
OOPS!
Nov 18, 2009
803
40
Idaho
If you apply enough throttle to register 1 percent, it disables the balance algorithm in the system. You can see this effect if you have efi live, watch the balance rates as you depress the throttle, the rates will all zero out corresponding to the rough idle, and one percent throttle give or take. Every LB7 that i have been in does this, and most LLYs as well. Can't speak for any engine platforms above that as I have not remembered to try it. It is a good on the fly way to check your injectors, if it is an erratic rough idle chances are you have nothing to worry about. If it is a definate or noticeable "miss" then you best be checking your balance rates, or having the thing checked out. Although this is a very very subjective and dirty test, it does give you an idea if you should drag out the testing equipment.
1chevy02
Jun 23, 2009
504
Mine and a couple others I know of will also shake slightly when you barely press on the accelerator.
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
Great info here thanks
stephen
May 8, 2011
Illinois
I have same thing just above idle and also drone/vibration at cruising speed 55-75 if I shift into neutral it goes away. Any body have an idea what's going on with my lb7.
