LB7: Lb7 coolant leak
jamesashtoncan
Jan 15, 2016
22
Ever since i got my truck back from the shop last tuesday, my truck has had a small antifreeze leak. As the time pasted i would just add coolant to make sure it was full. Here lately i would top it off and drive for about an hour and my low coolant light would come on. It looks like its coming out of the front drivers side of the motor. When i look under it is sprayed everywhere. Im new to the diesel world and would appreciate any advice or wisdom that yall may have. Thanks again.
Sent from my SM-G930V using Tapatalk
13,882
993
They aren't terrible. There is a writeup here that gives good instructions on how to do the work. A search should find it pretty easily.
Stancedlb7
Cummin Stroke this Duramax
Feb 9, 2015
649
SLC, UTAH
While you're in there do a compression test. Some times the coolant system gets over pressurized from a bad head gasket. Then the pump starts leaking through the safety port.
jamesashtoncan
Jan 15, 2016
22
Ok ill look at that in the mornin thanks josh. I really appreciate your input
jamesashtoncan
Jan 15, 2016
22
But thanks for your input. Ill do all nessesary testing while im there too. Is it hard to replace head gaskets also?
