Im confused why you need to command the shift solenoids on and off to see if they are working...what are you trying to do???
If the solenoid is commanded and the valve doesnt stroke (IE, the PSM doesnt see a change in pressure), the TCM will set a code. So if there arent any codes, the shift solenoids are working properly.......
