Hyperflash turn signals
8,238
as far as i know, you gotta run bens unlocked/tuned BCM to change that. otherwise its all about resistors...
gmduramax
Shits broke
Jun 12, 2008
4,190
328
Nor cal
I believe there are certain trucks for like construction or police that have leds, you’d have to find one and get the vin number and have a dealer flash the bcm with their vin. Not sure if that’ll work on 2011+ but 07.5-10 wasn’t a problem
3,150
wasn't it also a common option for cab and chassis trucks. don't know if it still is for the newer ones but I'm sure it was before the LML
ikeG
Oughta Know Better
Apr 19, 2011
2,557
192
Western PA
www.facebook.com
Local dealer service advisor called me back after some research and claims theres a flash for the bcm for box delete or cab/chassis trucks. We are gonna try that.
shakenfake
Moron
Sep 15, 2022
417
202
Shlumpt, TX
Someone on the SilveradoSierra forum literally just did this. Had the dealer flash them as if they had a flatbed and it worked.
Wonder if this is possible on a GMT-800....
3,150
per this document it looks like an option. even lists the RPO codes for it
  • MC-10205739-9999.pdf
3,796
423
The GMT800 has 2 different flasher part numbers. I don't believe they flasher module is on the data bus, but they're easy enough to swap out.
I've also heard the newer ones can be flashed as a cab and chassis to get LEDs to work right.
3,590
In the C5 corvette world, they have a hyper-flash harness that plugs into the turn signal wiring to solve LED issues. Its a T-harness with a relay. Works very well. I wonder if this is something that could be adapted to the trucks?
lutzjk
1,930
379
groveport, ohio
110% correct. I had my truck flashed with this.
