What does it take to put a boost sensor that will read higher on the Edge CTS on a LB7 say like 35 or 40 PSI I'm sure I have heard of this being done?
I have a similar Honeywell 100PSI sensor on mine, and it seems to work just fine!there is. just wanted to hear from a person that has done it I know Pat put a 100 psi one on something and it worked.
Here is a log showing 417.8 kPA (60.6 PSI) manifold pressure, or actual boost of 316 kPA (45.8 PSI):
The sensor I used is a Honeywell PX2EN1XX100PAAAX that I bought on Digi-Key for $96. I had to splice a plug in to the harness (the sensor comes with a pigtail), but it isn't hard to do. Works great!
Maybe. I know I can read it through EFILive just fine, but I have to use the BOOST_DMA PID to read it. I am not sure which PID the Edge reads. I also don't own a CTS to test it with, unfortunately.So I'm understanding this, with the Honeywell sensor you can read boost through the CTS without having to buy any more cables it just reads through the ecm like the edge is currently doing?
Does the boost register off the maf or is there a pressure sensor somewhere in the system that the CTS is able to read boost off of?
If I understand the OP's original question is how to make the factory sensor that reads boost read higher then the 23 lbs it reads factory
You can use any sensor you want just need to set it up in the edge. But you still need the edge accessory harness to hook it up
MAF is the measurement of air before it gets to the turbo before it gets turned into boost. yeah I'm wanting a sensor to change out and read higher than the stock sensor and read boost through the ecm by rescalling the table in the efi live tune to match the new sensors scale. you can make the factory sensor read more.
I havent used this one myself, but its cheap...might be worth a shot.
http://www.amazon.com/Pressure-Tran...DM58/ref=sr_1_2?ie=UTF8&qid=1422452921&sr=8-2
This^^ so the question is, is there a way
I know, I'm saying is there a way to make the factory sensor that reads a max of 23psi read more...
I added a connector to the pigtail on the Honeywell sensor that matched the factory plug, and just plugged it into the factory MAP plug. You could cut and splice in any connector you want, though.How did you wire that sensor in?
