hello from MN
malkintent
Mar 27, 2022
14
new to dmax but love it, well mostly, have some issues.
not sure which forum to post a question, just had a bunch of work done now its losing a gallon of oil in a 1000 mile out the exhaust, only smokes at idle then clears up, no lose of power, and idles great, where should i post this and yes i searched but cant find anything on this particular issue,
early 2015
190k miles
malkintent
Mar 27, 2022
14
ead gaskets replaced
head gone through valves done, new seals and 135lb springs
arp studs
egr delete
new down pie
cp4 to cp3 swap
new glow plugs
cold air intake
def delete new exhaust
things i had checked
pistons are good
cyl walls good
after truck was back together things i had checked
comp great
injector balance rates are great
no code runs awesome
then 1 week after rebuild started smoking blueish at idle when you give it gas big smoke till its running and clears out till you idle for 5 min or so.
also went through a gallon of oil in 1000 miles
took it back in and had it diagnosed as bad turbo, replaced it with a bd stage one
back together runs great but it went through another gallon in 1000 miles still smoking at idle.
3,588
Guys, I moved the tech posts to this gentleman's thread on his oil loss problem:
