are the heads from the lmm the same as lb7?
REDHOSS02 hard n heavy Jan 14, 2009 280 0 0 F U im from TEXAS Apr 13, 2010 #1 are the heads from the lmm the same as lb7?
Mike_S OOPS! Nov 18, 2009 803 0 0 40 Idaho Apr 13, 2010 #2 no. The injectors are different at a minimum. Last edited: Apr 13, 2010
REDHOSS02 hard n heavy Jan 14, 2009 280 0 0 F U im from TEXAS Apr 13, 2010 #3 i thought all that had to do with was the valve cover!
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Apr 13, 2010 #4 No the injectors are a different size and the lb7 head uses a injector cup were the newer style heads do not.
duratothemax <--- slippery roads Aug 28, 2006 7,139 10 0 Wyoming Apr 13, 2010 #5 LB7 and LMM heads are COMPLETELY different. LLY/LBZ/LMM heads are very similar.
REDHOSS02 hard n heavy Jan 14, 2009 280 0 0 F U im from TEXAS Apr 14, 2010 #6 well i have heads for sale then!
