Don't know where to post this so I'll try here
If the mechanic is changing the injectors are all the head bolts exposed so a change to ARP head studs one stud at a time, could be accomplished fairly quickly ??
If not what other stuff might be in the way to change to head studs ??
Has anyone changed the factory bolts to head studs one at a time with out changing head gaskets ?? And did the head gaskets last doing that procedure or did a head gasket leak because of lost clamping pressure while changing the bolts??
Anyone hear of any problems doing it one at a time ??
Saw some posts about a head studs only change being a possible cause for piston failure down the road since the block wasn't honed with torque plates.
But I'm not sure
I'd like to put in head studs for a turbo change in the future and if the motor is opened up now would be the time to do it.
Any knowledge on head stud swap ??
Thx
DD
But I'm not sure
Thx
DD
