Got Sludge?
lutzjk
1,930
379
groveport, ohio
Tom I agree
A oil change is cheap maintenance.
My son’s truck lost a lb7 engine side to a lower end issue. When we pulled the pan it was sludged up pretty badly.
lutzjk
1,930
379
groveport, ohio
With that being said.
We’ve pulled a valve cover off a 6.0 at work before and you couldn’t see the rockers……. So there’s that also.
3,589
A few weeks back, my mechanic at work was telling me that the idiots-in-charge in Atlanta have decided our trucks can now go 10,000+ miles between oil changes, and only need one Maintenance Inspection a year, two for trucks driving over 30,000 miles/yr. All I could do was laugh. Asked if we're going to be stocking engines on the parts shelves now? This company is famous for throwing $1000s of dollars at something to save $10. Idiots.
3,149
There os an argument for these longer oil change intervals, like the 10k mile ones.
Supposedly it takes time, heat, pressure or something else to cause the oil to do it's things and provide maximum wear protection. And regularly changing it early can cause premature wear. Today's synthetic oils are so good that for sludge to form there got to be more to it then someone doing 10k oil changes. Contamination, coolant, leaking head gasket, or something. But regular synthetic will not likely sludge in the recommended intervals
Here are a few studies that discuss this
lutzjk
1,930
379
groveport, ohio
It’s becoming more and more common.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,930
829
Central OH
For class 8 trucks that see tons of miles, there's always companies that will do extended drain. The money you save paying a shop (or your own tech) to do a service when running 100k miles a year (and 10-12 gallons of oil) makes up for an engine overhaul. Less maintenance costs and less downtime.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,516
590
At Da Beach
They just want to make ICE vehicles so expensive it would be cheaper to switch to electrics. The downsides seem less of a problem when saving money gets involved for corporations. lol.
Dozerboy
5,101
703
TX of course
I had used oil analysis done on conventional oil Delo 400 probably 15 years ago and it made it 16k before Blackstone recommend changing it.
3,795
423
Blackstone still recommends 10k+ miles changes on my Duraburb, but they dropped the recommendation from 5k to 4k on my blue truck this last sample. Guess the compound turbos (or my right foot) is harder on it than before.
This is conventional oil (Delo 400). I'm all for preventative maintenance, but if I have data showing I don't need to change the oil yet, I won't. 65k miles on the built motor and 200+k on the Suburban with no signs of sludge on either.
