Gonna get rid of my LMM...
Fastorange
Jan 31, 2009
256
ohio
I know you have a newer truck... But what are the balance rates on your injectors???? Could you have a boost leak????? Ive heard about some leaks on the charged air cooler. from people.. might be a place to start....
arneson
Aug 14, 2011
2,133
stoughton, wisconsin
Yeah I have been battling leaks also. Mainly after egr delete. Around the bridge. But u need to have someone look at your tune if u find no leaks. I own a landscaping company with a few 08-09 1ton duramax dumps which weigh 10k empty! and loaded, pulling, or empty never seen anything under 10mpg. Most of the time its 13 no matter what job there doin.
KidwickedLMM
Jun 12, 2011
70
I am running aftermarket wheels and tires. 305/55R18. Today when I was driving to a pull I noticed that my truck with the cruise set at 68mph is boosting 8-10psi..that can't be right?? Off topic I won the pull by 25ft and got thrown outta the stock class! With a bone stock truck! Haha. Guy says there is no way that can be stock, you beat my nephews dodge by 25ft! Haha. How do I check for a boost leak?
paint94979
Beer Nazi
Sep 18, 2006
11,742
33
I bet that is where your mpg is going... 0 boost at crusing speed is what you want. Like I said try a different tune
KidwickedLMM
Jun 12, 2011
70
I was playing with it when I left the pull to go get fuel (imagine that) haha. I can set my cruise on 35mph and it will boost like 4 or 5lbs..
07nastymax
Native Pride
Apr 21, 2008
111
St George UT
If everything mechanically has checked out, have you tried contacting your tuner about this issue?
I know you said it is a respected tuner, so he should be more than willing to help you out and try to fix this problem!
bean
Feb 5, 2011
66
Norwalk
my truck with the cruise set @ 70 will occasionally hit 2-5 psi but no more than that while cruising. Many members have said try a different tune and I recommend the same :thumb:
2005LLY
Sep 18, 2011
379
My truck use to see 15-16mpg in town, and about 18-19 highway.. Well now I've been getting 10mpg in town and about 16 highway.. Any ideas? Trucks got efi live, lift pump, and a tranny. I drive in my street tune from duramaxtuner, and I run a cat fuel filter.
Dirtymaxx03
3,109
i would check for low pressure fuel leaks man. even a small little steady drip will kill mileage.
Also, please try a different tuner before you sell the truck.
