Well it's settled then.......New goal :coolspot:
Well I'll tell you guys this much, I didn't strip out my truck and add a 10 point cage to roll over when someone beats my time. And if I can do what he did or better on a stock engine then that's even better. When this thing has a built engine and mark can tune it like a built engine i don't know what my goals will be but probably won't be 10s lol. I'm down but not out, we have a few things brewing that's for sure..
You and alot of other guys are super inspiring. Another huge reason I love this sight! I have faith you'll break records!
I wonder if a guy could cut the gears in a manual truck transmission like they do in a drag banshee trans?? Then you would just use the clutch off the line once and that's it? Not sure if anyone has ever done or tried it with a auto manual trans but if it could be done it would be kickass .
That's what I used to run in my drag rig and you just shift and slides like butter into gear without the use of the clutch damn near like a automatic.
I contacted liberties gear a while back and they so a product mod but mine would have been customThey are straight cut gears/ dog boxes from my search online used in lots of Rally cars for clutchless shifting . Not sure if they make such for a truck but if they do of it could be done you would have the fastest shifting truck yet. Not to mention how much easier it would be on the drivetrain than running the clutch .
I'm sure a guy could have a custom set of gears cut but I'm sure would be costly. Did a quick search and find them offered for some cars but can't find any for the ZF .
Isn't Jesse klennon stock engine lly at 10.7 he's yours to isn't he?
Time to pray and spray 5&6 jesse
That’s a sweet looking shifter! Might need one for mine![]()
Hand brake.... is someone going to build some boost instead 4K clutch dumps?
