Pretty simple.Here’s the testing sheet that came with my injectors. It’s all stuff I can research but if someone had time, I would love an explanation of the values and numbers on that sheet.
It "could" work in theory but I don't know if it would in actuality.Would it make sense to do a compression test and put the highest flowing in the lowest compression and lowest flowing in the highest compression so the power per cylinder is roughly evened out? Smother idle and less balance rate deviation?
I will go a little farther in depth on the explanation of this sheet. So the readings on the sheet are a volume which can be directly translated to a hp number at the crank available if everything is good. On a boost only setup I will go 4xmm3=Hp at crank and a heavy nitrous with boost combo will go 5x. This means on your sheet at 1350us you technically have 518hp available and at 1750us you have 670.8hp at that pressure on boost only. Hope this helps.Here’s the testing sheet that came with my injectors. It’s all stuff I can research but if someone had time, I would love an explanation of the values and numbers on that sheet.
I'm thinking the same.It makes you wonder if there was oil, fuel or something in the exhaust from before that took a while to burn out. I have seen that with blown head gaskets that put a bunch of antifreeze in the exhaust. The first test drive when you got on it would leave a huge white cloud.
A hose clamp put over the kinked area, not too tight, will 'stop the kink' and restore the flow.I kinked the fuel return line by the quick disconnect
Cheap replacement parts strike again....
