Fresh build over heating
quinton
1,883
Granbury Tx.
No I ended up getting a core trans and putting my clutches and everything in the other one. Drive it today and runs great until it gets warm then I come to a stop and get the p1711 code\issue. That's no big deal though I've got another valve body if I need it.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
45
ZEPHYRHILLS, FL
as to cooler flow, mine will blast a stream out after the coolers. i run -10 an lines, and it looks like a pressure washer spraying when i flushed mine. emptied the pan out in no time flat at idle. and thats an 01 without the g solenoid to drop line and increase cooler flow. and i thought you only grind the factory valve, NOT the transgo one?
