As far as the "flow thru" concerns of the air dog, it is a flow through design, I put a sump in after I installed the Ad2 165gph pump, and when I change fuel filters it pours out with intensity, before the sump it didn't though... I have 20k miles on my pump now, about 12k with the sump, pump is fine, going strong, the sump seeps every now and then and I tighten the bolts in a cross pattern and it stops, and actually, I have not had to do it in several months now.
As for reasons to install the sump...everybody has their reasons to do stuff, mine was because I didn't want to install a draw straw, I wanted to eliminate the 1/4 tank issues, and I get about 60 more miles out of my tank now before I fuel up, the mileage as slight as it is, was one of the bigger factors, I could probably get more but I don't ever carry fuel and I don't really feel like pushing it. Also, the pump will last longer if it is gravity fed v.s having to suck fuel up the pick up tube or even a draw straw, being gravity fed makes it work less, it runs quieter too, which tells me it is working less and therefor running cooler and going to last longer too
Even though I don't have the power/fuel flow needs to support "needing" a sump, I felt like there are several other contributing beneficial factors to having one.
